ADAGIO SW 1714 SERENE WATERS WALL FOUNTAIN - RAJAH FEATHERSTONE
Features- EZ install bracket makes set-up simple
- Simple on/off switch controls both the lights and the water.
- The welded plastic liner is double tested and prevents against leakage.
- A uniquely designed water distribution unit system won't clog thus giving you even water flow.
- Only one cord plugs into the wall and is easily concealed behind the water fountain with a 90 degree plug.
- Durable powder coat finish on all of our painted metal trim.
- Fully contained.
- Finish - Textured Black
- Color - Rajah
- Water Surface - Featherstone
- Dimension - 21 Wide x 36 High x 7 Deep in.
Included- Hardware to hang on a sheetrock wall
- Halogen Lighting and 1 bulb
- Polished River Pebbles
- Electric pump
Price: 615.18
